axle bearing question?
Old Jan 15, 2008 | 05:51 PM
Pitkin1's Avatar
Default axle bearing question?
I am in need of the bearing that is circlipped to the splined shaft of the rear axle that mounts in the rear differential. I can't seem to find it on any of the parts diagrams. I am hoping it comes seperately and not just with the whole axle assembly.
Old Jan 15, 2008 | 11:26 PM
JasonSC's Avatar
Check here in the diagrams. http://www.babbittsonline.com/...rand/3/ArcticCat.aspx
Check 'rear drive gearcase assembly' It has several bearings listed, and I'm not sure which one you're looking for.
Old Jan 16, 2008 | 12:39 PM
mudslinginfool's Avatar
Does it in the Mud!
im confused. do you need a wheel bearing or are you saying there is a bearing on the axle on the side that goes into the differential? ive had my half shafts out 8 times and never seen a bearing near the differential end on an IRS.the shaft just slides in and out. ive only seen a wheel bearing. which if this is what you are wanting, then yes the bearing is seperate. about $30- 35 at the dealer. part #0402-275, but mine is a 2002 so maybe they changed it for the 2005s.
Old Jan 16, 2008 | 02:42 PM
Pitkin1's Avatar
I shouldn't have called it a wheel bearing, the one I am looking for is mounted in the rear differential. The splined end of the half shaft slide in it and it has big steel ball bearings that show. The Cat service manual shows how to take it out but says to replace the whole axle if it is bad, so it doesn't show up as a seperate part as near as I can see.
Old Jan 16, 2008 | 03:10 PM
JasonSC's Avatar
Did you check that babbits link? It looks like some are seperate part numbers.
Old Jan 16, 2008 | 05:51 PM
Pitkin1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JasonSC
Did you check that babbits link? It looks like some are seperate part numbers.</end quote></div>
I already ordered a part from Babbits that I thought was the right bearing and it wasn't. It was an internal bearing, not the one the half shaft slides into.
Old Jan 16, 2008 | 06:07 PM
Pitkin1's Avatar
Sorry for being so ignorant, but my whole half shaft, hub and wheel puller out of the differential as my atv was rolling down a side of a mountain in Colorado.
So not all the pcs are intact for me to look at. So what I need actually is the inner CV jount that mounts to the differential. Is this sold seperately?
Old Jan 16, 2008 | 08:17 PM
JasonSC's Avatar
You can rebuild that part of the axle, yes, but not sure about the rear diff internals. I've never went inside the diff, but I'm sure it can be done. I've had to rebuild and pach together way too many axles though...[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jan 16, 2008 | 08:19 PM
JasonSC's Avatar
Maybe if you could email me a pic of the parts.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
Chuck188
Jul 17, 2015 02:45 PM
Rider252
Jul 6, 2015 03:37 PM
