removing grips without ruining them
Old Jan 23, 2008 | 08:58 PM
700 sportsman's Avatar
Default removing grips without ruining them
any tricks to getting them off or should I should I just cut them off??
Old Jan 23, 2008 | 09:09 PM
oldturtle's Avatar
I loosen all controls from inside of grips and slide them inward. Then slide a skinny screw driver into grip from inside. Insert WD40 spray nozzle and spray. Do again on opposite side. Start twisting grip until it comes loose.
Old Jan 23, 2008 | 09:12 PM
thanks oldturtle
anybody else??
Old Jan 23, 2008 | 10:23 PM
pamotorman's Avatar
blow into the end with compressed air this will expand the grip and allow it to slip off. if there is a hole in the other end you must have someone hold their finger over the hole to prevent the air from coming out
Old Jan 23, 2008 | 11:52 PM
Hebs's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pamotorman
blow into the end with compressed air this will expand the grip and allow it to slip off. if there is a hole in the other end you must have someone hold their finger over the hole to prevent the air from coming out</end quote></div>
definitely the easiest way...
Old Jan 24, 2008 | 12:27 AM
EdKatt's Avatar
Grips are cheap. Buy new ones.
Old Jan 24, 2008 | 12:42 AM
polarisman600's Avatar
i never really tried to get them off without cutting due to being hard to get off. easiest way would be to just cut them off. like edkatt said they are cheap.
Old Jan 24, 2008 | 05:19 AM
Faster250R's Avatar
Well, I would suggest the same program as old turtle, but I found using Berrymans (or any carb cleaner... brake cleaner works too) instead of WD-40 will leave the "sticky" on the inside of the grip where WD will leave oil. Just when you go to put them back on, give the inside of the grip another shot of spray to help it slide right on.... then she will be stuck back on like new!
Old Jan 24, 2008 | 05:26 AM
CaptainQuint's Avatar
Any time I have to pull grips off I use it as an excuse to change them out.
I've got a nifty new blue set out in the garage I'm looking for an excuse to put on.
Old Feb 7, 2008 | 09:48 PM
zaptoad's Avatar
WD40 will work, but I perfer to use gasoline in a squirt bottle. It doesn't leave an oily residue and create future grip issues. My wife wears contacts and the bottles the water comes in works great. I save them all because gasoline will melt the tips in time, so lay in an inventory. I use them for a lot of different things, thier great!
