Removing tire 300ex
How do i take my tire off, i couldnt make it let loose of the rim, i ran over the tire and finally i cut alot of rubber off and got to the wire and i cant quite cut it what ithe proper way? i still have another
I have a square tube about 4ft long with a flat piece of steel welded on the end of it so I dont hurt the tire.I lay the tire on the ground and put the end of the pipe with the flat steel right up next to the rim then I drive my truck up the square tube.Sometimes it will not pop it off right away but usually if it sets there for about a minute it will usually break it down.May have to rock the truck a little while its parked up on the steel tube.Thats the way us rednecks do it.
Yea well, i cannot do this because i cut the sidewalls out of my tire so all thats left is a little bit of rubber around the rim were it is like pasted to it, so their is nothing to put a 2x4 on and hold the board.
When I had to change my tires on my rubicon, I used a manual tire changer from harbor freight which works pretty good. Also leave a little bit of air in the tires. That way the sidewall will not collapse.
