03 Viper rev Limiter??
Old Jan 27, 2008 | 07:42 PM
FULL-THROTTLE's Avatar
Default 03 Viper rev Limiter??
I keep hearing about rev limiters on the eton's, I have an 03 viper 90, It does not have an adj on the ignition box, ( cdi/coil), any idea's if the stock one is limited? If it does what can I expect if I replace it with non-limiter?
Thanks,
Fran
Old Jan 27, 2008 | 08:18 PM
hotblooded's Avatar
It should have a limiter on it. There should be a green wire that comes out of the cdi and loops right back into it. Take and cut the green wire and make sure and tape it. This will take care of the rev limiter. You still wont get extreme rpms with a stock carb and exhaust. They do offer a aftermarket cdi for it as well. Keep in mind that you may have to change the weights in the front variator(clutch).Hope this helps.
Old Jan 28, 2008 | 12:37 AM
Thanks,
I will give it a try and see what happens,
I am planning on a new pipe, carb and clutch/variator springs and weights.
I will post the results when it get it completed.
Fran
Old Jan 28, 2008 | 10:08 PM
cdlightening's Avatar
yes it does have a limiter
flyin-lowe
Dec 1, 2017 03:18 AM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
