another question about fade plastic...
Old Jan 29, 2008 | 02:44 PM
quad 4's Avatar
Default another question about fade plastic...
Hi..
I do some search about make more glossy my atv plastic....What happen is ....when I removed my big sticker it make the plastic fade with no bright on it. I try wax it with MEGIRE FIBERLASS WAX with not a great result...you can see the difference on my plastic where I removed the sticker....anyboby got some idea what to do ??? DO I have to wax it again and buff it.....a couple of layer.....I just polish with a cotton rag right now....
If you got experience please help....
Old Jan 29, 2008 | 02:56 PM
TarHeel1's Avatar
Try furniture polish. it's cheap and something you probably have at home already plus Polaris recommends the stuff. Other than that I'd lightly buff with a compound and then wax. Good luck
Old Jan 29, 2008 | 03:03 PM
quad 4's Avatar
I want to try pledge wax this weekend. When I take my new X2 at the dealer...I know they put some PLEXUS stuff on it......Some one talk to me to heat again the plastic to going out the true bright color...but I did it when I remove my sticker !!!
Old Jan 29, 2008 | 04:55 PM
Sandman2.0's Avatar
Pledge is the best thing I've found to date for plastic. I use it on all my dirt bikes and ATV's. It also works great on clear plastic windscreens and helmet visors.........and it smells nice too..........be warned though, it attracts bees!!!
Old Jan 29, 2008 | 07:18 PM
shoals outdoor's Avatar
PLEDGE ALSO LETS MUD WAS OFF MUCH BETTER. YOU WILL PAY FOR A CAN OF PLEDGE WITH MONEY SAVED AT THE CAR WASH
Old Jan 30, 2008 | 12:51 AM
Krammer220's Avatar
This may be a little risky... & I'm not recommending it,but I took a propane torch and just very quickly "licked" it over the plastic while buffing out the freshly heated area with a rag held in the other hand.
It doesn't take much...You really have to be careful not to overheat the plastic or stop moving the torch at any time(I bubbled a small spot under the rear rack,as I started there to kinda get a feel for it)
I did this to a severely faded 98 xplorer with great results... it really brings the shine back.
Old Jan 30, 2008 | 09:28 AM
quad 4's Avatar
Krammer220..
At a motorcycle part shop nearby...the guy told me about using a HEAT GUN.....but be very carfull to use it. We spoke a lot and all the product they sold like Plexus, and other product not suppposed to work for my kind of fade.......They told me I have to take back naturaly the gloss of the plastic itself. I want first try this weekend with a hair dryer very close to the plastic.....just a ty. The pledge after that is the second option......third one maybe a buffer ??? Will see.
Thanks all for the help..
Old Jan 30, 2008 | 07:32 PM
TxMagnum's Avatar
Krammer220 is right. I have to say pretty much the same thing, to heat the area with a torch CAREFULLY. This also will help to remove white creases in plastic. If you have something to pratice on, anything that is heavy plastic that might shine I would suggest doing so. Its kinda tricky and I have screwed up some plastic before. Good luck
Old Jan 30, 2008 | 07:55 PM
quad 4's Avatar
TORCH.....I had to make a try this weekend....I got some high density plastic to test it...
Old Feb 4, 2008 | 09:47 AM
quad 4's Avatar
Ok...
I try propane torch on a old yamaha 225 1986 and the fender wanna gloss...but kinda want to melt in the same time.....I try on another utility AMT 600 John Deer 1985 and I could not see some gloss comme up with this method. Second I try the PLEDGE on my fender and right away I see the gloss on it but I cant gloss the part where the sticker was.....So I take some GAZ and I aply on all my fender....it make a dull finish.... but equal on all my fender. After I aply a marine MEGIRE WAX on the fender and the dull finish desapear.....Is NOT gloss as NEW but is EQUAL gloss on all my fender and look like the rest of my quad.
I'm Happy now.
wendal
Aug 3, 2024 10:03 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
