Help H1 wont start
Old Jan 31, 2008 | 12:38 AM
ArcticMan 05's Avatar
Default Help H1 wont start
I got a 2007 650 H1 yesterday rode it for bout 20 mins ran fine no problems! Killed it came inside for bout 15 mins went back outside to put it up and craked it. It cranked but then started spitting and sputtering like runnin out of gas so ok. Left it where it was till this morning, went got gas filled it up and now it will not even start just keeps turning over! Like not gettin fire or gas! But know its gettin gas. Gas is runnin out of bottom of carb. Took out spark plug, lil fuel fouled but not bad! Got new one be here tommorrow. Nother question, if ya unscrew the screw on bottom of carb is gas just supposed to run out? I need help quick fast and in a hurry got big ride this weekend! Ok been workin on it all day heres what i got! I've got fire when i pull out spark plug and ground it, it'll jump fire for bout 3 inches. But when put plug in and try to crank it and pull it out it still dry and doesn't even smell like gas or anything! I even tried to hold my hand over back of carb to make it choke and no luck just shoots gas out of vent line under instrement pod! I don't know i've took the carb off and cleaned it and done everything i know to do to it! I've got and old carb from my 500 put it on there did the same thing! somebody please help me!
Old Jan 31, 2008 | 11:45 AM
devill's Avatar
did u take it apart and clean it??? the needle valve could be stuck open..
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
