250 or 400?
Old Feb 2, 2008 | 05:56 PM
WiCkEdTrAiLbLaZer23's Avatar
Default 250 or 400?
i am 16 and have the trailblazer in my signature
with a budget around of around 3500.
that is including the money i intend on getting from the trailblazer i sell from which i have a solid customer. do you guys think i should keep the 250 and stroke it or buy the 400 and modify it?
any info would be useful
Old Feb 2, 2008 | 05:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 250 or 400?
if you want alot more more and speed, there isnt even a question the 400.
Old Feb 2, 2008 | 06:16 PM
dwhst9's Avatar
Default 250 or 400?
No replacement for displacement!
Old Feb 2, 2008 | 06:55 PM
ftwflh's Avatar
Default 250 or 400?
Port the 250( dont stroke it) ride it while saving more $$$$ because you will need a bunch on a 400.The mods never seem to end on a 400.Too much power to be had but it aint cheap.
Old Feb 2, 2008 | 07:12 PM
Default 250 or 400?
so you think stroking it is a bad idea?
how much should a used 400 run?
Old Feb 2, 2008 | 07:19 PM
ftwflh's Avatar
Default 250 or 400?
Stroking wont get you what it cost in power compared to the 400.A good port job on a 250 with your pipe should get you running close to a stock 400.
400s run anywhere from $1000-$4000.A decent 2x4 runs avg $1500 then the cash flow starts.You would end up with close to $4000 in one by the time you get all the work done(pipe,porting,girdle,carb,reeds,clutching,susp ension upgrades,wheels&tires)
If you like the 250 stick with it save your cash buy a 400 to mod a little at a time and still have a ride.
Old Feb 2, 2008 | 07:31 PM
Default 250 or 400?
how much would a stroker be and how much power would it put out?
Old Feb 2, 2008 | 07:42 PM
ftwflh's Avatar
Default 250 or 400?
A stroker kit w/reed conversion will boost power but not as much as what you have to pay.
Old Feb 2, 2008 | 08:01 PM
Default 250 or 400?
my parents are kind of determined to keep my quad so wat could i do with 300 dollars to modify it
Old Feb 2, 2008 | 08:04 PM
Default 250 or 400?
i meant 3000
