my 96 scarmbler overheats and coolant comes out the resivor,boiling
i have a 1996 scrambler 400,and it over heats and the coolants comes out the resivor,iwas thinking it was the thermosat but there is none,then thought it was the water pump, any way i can test that? or what other possiblites could it be?
if the waterpump was bad it wouldnt take very long to overheat the engine and the antifreeze wouldnt be hot all through the system. howlong does it take to overheat it?
last i ised it ,it was 80 degrees out, and it took maybe 15 min to over heat,is there a way to test the pump? like disconnect the tube after it and start it to see if its pumping the coolant thru?
jrooker6
Apr 23, 2016 07:36 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
