05 Polaris 700 EFI
They found some bad wires the first time and replaced the whole wiring harness, assuming this was the problem. They said it was showing no codes and they could not seem to get it to repeat the problem. Unfortunately everytime I ride it I have the problem. So now what? They say fuel injection is pretty basic, however I have no clue, nor does Polaris. The strong odor of gas should tell someone something and not running at idle, Does anyone know?
I Have a 05 700 with 3000 + miles on it, have had to replace baro sensor connector 2 times know. at that time it smells rich and runs bad. check wires at the base of connector. I carry a extra with me know
member of Colorado Quad Runners
Thanks trail blazer can you tell me where to find this censor? and a part# would be great. I have looked and do not see any type censor for fuel injection. I could really use some help here.
Wiring connector is wright by the ait filter box, take the top of the air filter box off, look under air snorkel and there is a black rubber air intake hose, it is in it. Check the wires at the end of the connector real close, they brake off make sure no crakes in insulation. My crank case breather tube was on the left side of air box, I moved it to the right side it was rubbing on connector and wires. I carry a extra on with me on long trail rides. When I go for 100+ miles a day
If you find wires broke make sure to use low temp soder connectors, crimp connectors wont work properly on low voltage
