backfiring honda
Old Feb 13, 2008 | 09:14 PM
bluehonda's Avatar
Default backfiring honda
have a problem with my honda not starting,backfired a few times when trying to start it,now will not fire or backfire.checked plug was carboned but visually ok,when turning over had vry week intermitent spark. WHAT IS WRONG? and what needs replacing? sorry the atv. is a Honda forman 400 4x4 blue factory color.dont know the exact year. probably late 90s or early 2000. thanks for any help you can offer......
Old Feb 13, 2008 | 09:40 PM
QWODER's Avatar
I'd go ahead and change that spark plug if you haven't yet.
Old Feb 14, 2008 | 12:51 AM
bluehonda's Avatar
Thanks...that was the first thing I did......absolutely no difference.....any other suggestions? Besides taking it to my nearest Honda dealer?
Old Feb 14, 2008 | 01:29 AM
DennyRoark's Avatar
Have you checked your timing yet? That will cause backfiring. Lean mix will back fire on deceleration as well.....
Old Feb 14, 2008 | 08:44 AM
QWODER's Avatar
Try draining the carb.May be a screw on the very bottom of carb that you can unscrew a little to drain.May not be the problem but try it before you go to dealer
Old Feb 14, 2008 | 01:47 PM
hondabuster's Avatar
The carb is probably plugged up, and needs a good cleaning. Make sure to focus on the starter jet, and pilot jet, and youll probably find one of them plugged.
Old Feb 17, 2008 | 09:13 PM
pat89's Avatar
Yes, it does sound like you've got a dirty carb. Also, check to see if your choke plunger is sticking but most likely one of your jets is clogged. A blast of air will help.
donintennessee
Jan 8, 2021 12:40 PM
COFatboy
May 2, 2020 12:06 AM
donintennessee
Aug 19, 2015 02:22 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
