suspention problems??
Old Feb 14, 2008 | 08:35 PM
vinman18's Avatar
Default suspention problems??
hey, I havent riden my 4 wheeler for about 5 days. today it was about 15* F out and i went to take it for a spin, and the front shocks was totaly calapsed, all the way down. the plastic was rubbing on the tires and it didnt absorb any bumps at all. anybody know if something was frosen of my suspention took a dump, i have no clue.
thanks
Old Feb 14, 2008 | 08:41 PM
sprinter10's Avatar
I have no clue at all take a pick and put it up its hard to hear what you are saying is the sprint fully compressed?
Old Feb 14, 2008 | 09:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like the charge has gone out of the shocks. are they leaking any fluid out of them. not sure if their oil or nitrogen or not.
Old Feb 14, 2008 | 09:30 PM
sprinter10's Avatar
i don't think the charge in the shock would effect the shock dropping. im my old race car we whent thre shocks all the time and when they were bad they leeked but never would drop they would just move up and down easy. the sprint is wat holds it up and if that somehow goes it would drop. shocks just damper the rebound and compression of the shock
Old Feb 14, 2008 | 09:32 PM
sprinter10's Avatar
did the top of teh shock possibly break off the mount? or come loose and pop off at teh top? that might do it.
Old Feb 15, 2008 | 12:21 AM
vinman18's Avatar
the shock isnt leaking anything. but the spring and absorber are 100% commpresed (sorry about the bad description before) . it looks to me like everything is hooked up. il take some pictures and hopefully that will give you a better idea at whats wrong.
Old Feb 15, 2008 | 12:28 AM
sprinter10's Avatar
I never saw this before is you atv outside or in a cold garage of it is put some heat on it see if the shock releases idk maby the a arm is seized try picking up the atv and put it on a jack or jack stand and then push down on hte tire to releis whatever is holding it. is the a arm bent were the tube is on the frame? crimped. and for you to get it that compressed you must have done something hard. did you pull a weelie or something? hit a jump?
Old Feb 15, 2008 | 12:37 AM
vinman18's Avatar
no im preaty nice to this atv i dont do jumps or wheelies. but i do go through mud and water alot . so some water could of got in there and frose up. i keep it in a non-heated shed. but il put it in our heated shop and put it on jack stands see if it will stretch out a little. by the way hears a picture that i took before it went flat.
http://s272.photobucket.com/al...&current=IM0042671.jpg
Old Feb 15, 2008 | 12:41 AM
sprinter10's Avatar
do you have a picture of it now with the suspention problem?
Old Feb 15, 2008 | 07:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i dont see anyway that it would freeze or anything else w/ the springd at full compress. even w/ the shocks junk it wouldnt colasp w/ the ssprings in place. if you have a pic of it compreesed, or is it not al the way but half way compressed would be weak springs and or shocks.
