Custom ATC 138X
Single cylinder, 4-stroke, 2 valves, OHC racing head, oil cooled, 138cc
Bore x Stroke: 54mm x 54mm, this is a 'square' engine for best balance between power and torque
Dimension: 17"X11"X9"
Valve Sizes: 27mm intake, 23mm exhaust
Displacement: 138cc
Compression Ratio: 9.47:1
Carburettor: 24mm MIKUNI racing carburetor
Ignition: CDI, 12 volt, permanent magnetic stator
Maximum Power: 8.5 Kw DIN @ 9,500 rpm
Rated Power: 6.5 Kw @ 7,500 rpm
Torque: at least 8.8 Nm @ 5,500 rpm
Gears: 4-speed, manual clutch, START IN ANY GEAR! 1-N-2-3-4, 1 down 3 up.
Gear Ratios: 1st 2.833:1, 2nd 1.706:1, 3rd 1.238:1, 4th 0.958:1
Final Drive: 14 tooth #420 front sprocket included (we have other sprocket on sale too!!)
Lubrication: 1.1 litres, 5W/40 4-stroke motorcycle oil, pressure and splash
Fuel: Unleaded
Package Contains:
Buyer will receive Lifan 138CC Motor, 24MM MIKUNI Carbruetor, Billet Oil Cooler Radiator, Intake manifold, intake gaskets, Shifter, Kick Starter, Wiring Harness, CDI, Spark Plug and Ignition Coil. This pakcage has almost everything, excepts a bike to bolt on.
Check out the exhaust system I have my eye on.
Man is this thing going to be sweet when it's done.:w00t:
Tires and rims come in Tuesday.:w00t:
Mmmm looks like I mite be upgrading the motor.
Displacement: 138cc
Fuel: Unleaded
Package Contains:
<div class="FTQUOTE"><begin quote>Originally posted by: hondaatc185
hey. that thing is going to be SWEET!! i wanted to know...where did you get the forks...? i have a 185s i need shocks for!! well just let me know...</end quote></div>
Those shocks are for a 1985 200M.I got them in a trade.
<div class="FTQUOTE"><begin quote>Originally posted by: customtrikes
Those shocks are for a 1985 200M.I got them in a trade.</end quote></div>
o ok..do you know where i could hind some? there are NONE one ebay...
Here are some 200 that mite work.
<a target=_blank class=ftalternatingbarlinklarge href="http://cgi.ebay.com/ebaymotors/Honda-ATC-200-ATC200-Forks-Shocks_W0QQcmdZViewItemQQcategoryZ43974QQihZ024QQi temZ370020389942QQrdZ1QQsspagenameZWDVW
">http://cgi.ebay.com/ebaymotors...sspagenameZWDVW
</a>
<a target=_blank class=ftalternatingbarlinklarge href="http://cgi.ebay.com/ebaymotors/HONDA-ATC200S-ATC-200S-FRONT-END-FRONT-FORKS_W0QQcmdZViewItemQQcategoryZ43974QQihZ016QQit emZ260146285287QQrdZ1QQsspagenameZWDVW
</a>
Are you being specific?
http://cgi.ebay.com/ebaymotors...QrdZ1QQsspagenameZWDVW
They look the same to me.
</a>
</a>
