650 H1?
Alright i have blown 2 ignition fuses on my 650 and it only has 80 miles on it. What would cause it to blow a fuse? It's not a huge problem anymore, i can change it pretty quick know, but the first time it happened it took me awile to figure it out.
what is the fuse connected too. what stops working due to the fuse blowing.??? the blown fuse is a short. or an overload. they make circuit braker style fuses that you can just reset rather than having to change the fuse out all together. but you need to fisure out what is causing the fuse to blow in the first place. my guess is your fan circuit???
Sorry i forgot to say that it is the ignition fuse blows. When it blows the bike won't start and the display won't turn on with the key. I think i may take it in since it is under warranty, but if it is an easy fix i can probably do it myself.
youve got a short somewhere. obviously in your ignition system. if its under warranty let them do it. a short can be a pain in the *** to find. it can also be easy enough to figure out. your looking for any pinched wires and bare wire touching metal loose connections. but again why bother if you can make someone else fix it.
