need help
Old Feb 17, 2008 | 03:06 PM
crazyrick666's Avatar
Default need help
i was wondering if anyone could tell me what the biggest set of tires i could put on my 2004 honda rancher es 4x4 without rubbing to much also what other items should i get and where is th best and cheapest place to get them
i was planing on getting a
2" lift kit
a ramsey 2500 winch with wireless
a jet kit / k and n filter
a snorkel kit
and i was between the intraco swamplites or Kenda Executioner
any thing else i should get ?
and if i have stock tires what is the biggest set of tires can you install on them
or is it best to just get new rims and tires
my stock tires are front at 24x8x12
rear at 24x9x11
i used to own a 2006 grizzly 660 camo and i sold it cause i hated it so i recently purchased this quad for $2000 off a friend it has been sitting in his barn it only has 50 miles on it is (he won it in a raffle) it is mint but i was also wondering is their anything else i should do to it since it only has 50 miles on it
i love the deep mud so i need help
Old Feb 17, 2008 | 04:58 PM
hondabuster's Avatar
Default need help
Youll end up hurting the horsepower and top end speed alot more with bigger tires, and rubbing will be the least of your concerns. I personaly wouldnt go bigger than 25 inch, and I wouldnt go too deep on the lugs, because a 350cc is alot lower on power than that old grizz was. The executioner tire is gonna be way too much for that motor to pull.
Old Feb 17, 2008 | 08:07 PM
Default need help
so would you go with the swamplites
Old Feb 17, 2008 | 08:38 PM
pat89's Avatar
Default need help
I have been running 26" Bugs on my 2000 Rancher for 6 years. I originall installed them without any upgrades but added them as time went on. Before jetting, adding a K/N cleaner, and pipe, it really struggled turning them in deep mud. After adding them and a clutch kit, it turns them like it did the stock tires. They have never rubbed. I can not recommend the High Lifter clutch kit enough. To do it again, it would have been my first mod after adding the tires, along with my Warn 424.
