Help
Old Feb 24, 2008 | 01:55 PM
johndoe1983's Avatar
Default Help
I know this is the wrong forum!
I have a crappy Kazuma 250 Falcon. Recently when i give it full throttle it bogs out and does not want to accelerate very fast!
Any suggestions- first four wheelers and it sucks just need some direction
Old Feb 24, 2008 | 05:13 PM
recon99's Avatar
Default Help
Push it off a cliff, that's the best thing to do with these cheap taiwanese and chinese toys. Watch out for the lead paint too lol.
Sounds like you definitely have a carburetor problem. The first thing I would do is take the carb apart and clean everything out real good. It only takes a little bit of dirt, a spider leg (surpirsing how many spider legs can make it into a carb, it's weird) or anything like that will block your main jet and keep the engine from getting fuel when the throttle is opened about 1/2 of the way up to full throttle. Especially on these smaller, cheaper machines dirt in the carb tends to be a common problem. Not only are the vent lines usually run to poor locations where they aren't protected from contaminants, but also because a small engine with a small carb like this will have very small, easy to block passages and jets in them.
Old Feb 24, 2008 | 09:14 PM
Default Help
Tried that with carb cleaner? Will do again.
Thanks for your response
