YT 125 TRI-MOTO
Old Feb 25, 2008 | 09:00 PM
postalbeee's Avatar
Default YT 125 TRI-MOTO
Hello All,
I got this bike for cheap for my kids to ride before I get a good one. I had to clean out the carb and replace the pull start. I give the bike a good cleaning inside and out. I got the bike to Idle and run But for some reason the 125 while ridding. It spits and spudders about half throuttle. The 125 acts like its choking and spits and spudders. As soon as I let off the gas the bike runs great. Shifting gears also doesnt help. It happens in every gear. I think it might be getting to much gas or not. When I put my hand on the back of the carb to close off the air. It dies and my hand is like soaked in gas. Any Idea
thanks
Old Feb 26, 2008 | 01:10 PM
87 warrior's Avatar
sounds like it's flooding it's self out. try and adjust your floats in the carb bowl. i'm not sure what your float level is but i'm sure if you don't have a manual you could look it up on the net somewhere.
Old Feb 26, 2008 | 03:04 PM
postalbeee's Avatar
I've been looking on the net. So far no luck. The floats close off at level. I got a piece of tube and blew threw it and slowly closed the floats till there was no more air coming out of it (OLD TRICK IF YOU DONT HAVE A BOOK) Floats were level. Maybe I chould let them cut off a little sooner. I thought may needle on the slide might be the cause or gap on the points. I'll check on the net for float level maybe get a better range of options.
Thanks
Q--->
ATC 3-Wheelers
Jul 26, 2008 05:37 PM
Q--->
Jun 17, 2008 11:52 PM
thomasbynum
ATC 3-Wheelers
Apr 17, 2007 06:49 PM
KNOWSALOT
Feb 19, 2004 03:52 AM
minnesotaMOJAVE
ATC 3-Wheelers
Jul 22, 2002 07:49 PM
