400ex
Old Feb 25, 2008 | 09:54 PM
go-hard-or-go-home's Avatar
Default 400ex
one of my 400ex's runs crappy!!!!!!!!!!!!!!!!
its in the carb. so for you honda carb guys this ones for you!!!
it leaks and leaks and leaks.. my carb can not get no cleaner!! it had no hoses on the carb as far as the vacume and over flow lines. so i put new ones on. then i cleaned the whole carb. put it back together and it still leaks out of the over flow line???
WHATS WRONG?????????????
Old Feb 25, 2008 | 11:49 PM
Gimpster's Avatar
Default 400ex
I normally have advice for almost everything on here. This one I am watching for an answer also. I have a 400ex carb in my junk box at work that was off of a brand new 400ex around 4 years ago. We replaced everything new on it and it still leaked. Pretty much been used for a parts donar since I condemned it under warranty
----- Gimpster -----
Old Feb 26, 2008 | 01:14 PM
Bounce400ex's Avatar
Default 400ex
Just a thought.......Float problems? Is there any gas inside the float? What condition is the float valve and seat in? Maybe the spring in the float valve?
Old Feb 26, 2008 | 05:40 PM
Default 400ex
its a rebuilt carb. its all new. the floats and needle are all fine... the only thing is the floats are all plastic and you cant addjust them.
it wont stop leaking.
Old Mar 3, 2008 | 01:28 PM
madmac3rs's Avatar
Default 400ex
I experienced a similar issue on a 400 foreman. The problem that I found is that the pin that goes through the float was very loose, the holes were worn in the carb casting, and since the float was all plastic it could not be adjusted out. Had to replace the entire carb for the customer. (probably could have "rigged" something but that didnt meet my standards for "quality repair"). this might be something to check.
Old Mar 3, 2008 | 01:38 PM
Default 400ex
thanks everyone!!!!!!!
put it back together, now its fine. its a mistery...
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
