2005 650 v2 fan
Old Feb 27, 2008 | 06:49 PM
Max4's Avatar
Default 2005 650 v2 fan
My 650 v2 cooling fan seems to run an awful lot today I was just out around the yard maybe riding for a couple of minutes and the fan came on and it stays on ,maybe this is normal but it was -2 celcius out so I didn`t think the fan would come on that quick it doesn`t seem to overheat its just that the fan runs alot .What are your guys like that have the V2`s is there something I can check the bike is super clean and the rad is clean as well .thanks for any info
Old Feb 27, 2008 | 09:43 PM
rango726's Avatar
you can add some liquid ice. is an addative that lowers cooling temps. alot of people use it
Old Feb 28, 2008 | 04:16 AM
Chumley's Avatar
You cannot "add" Liquid Ice. You need to flush the old, rinse, and refill with straight Liquid Ice, it is premixed.
Just clarifying before someone just throws in a few cups of the old LI.
Old Feb 28, 2008 | 05:52 AM
Max4's Avatar
What I`m wondering is if the fan is coming on prematurly or if these bikes are made to run hot .if the bike is designed to run a little hotter then putting in a coolant that runs alot cooler can`t be good for it either can it ? I really don`t want to do anything that will cause me grief in the long run
Old Feb 28, 2008 | 07:41 PM
rango726's Avatar
i have a 400 so i cant speak for the v2. but i know alot of people use it so it cant be to bad. and i didnt get into specifics on how to use the product thats his deal. i just assumed hes pulled the radiator and changed the coolant.
Old Feb 28, 2008 | 10:02 PM
catmanv2's Avatar
Folks I think he's wondering if it is normal for the fan to kick in that often or that quick. I know mine doesn't.
Old Feb 29, 2008 | 07:49 AM
Capt. Bob's Avatar
My 07 H1 seems to cycle a lot also. The coldest I have rode it in is 70 degrees. You have to remember though. It is not like a car going down the highway at speed forcing the air into your radiator. You are are going slow and not moving much air at all so it is probably normal for this to happen. JMTCW
Old Jul 4, 2008 | 05:49 PM
pacer650's Avatar
Do an antifreeze test to see what temp. its good for. If its ok check to make sure your thermostat is functioning properly.
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
