Another front fluid question
Old Mar 3, 2008 | 12:28 PM
so2315's Avatar
Default Another front fluid question
I have a 2007 800 X2 Standard. It doesn't have the ADC. Reading all of these posts about fluid just makes your head spin. What type of fluid does the regular front differential take w/o ADC?
Can we get someone to make a simple post that can get pinned up top?
Old Mar 3, 2008 | 02:07 PM
Kerbbirds's Avatar
Without adc it takes the premium demand drive hub fluid.
Old Mar 3, 2008 | 02:31 PM
so2315's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Kerbbirds
Without adc it takes the premium demand drive hub fluid.</end quote></div>
The manual states Demand Drive LT Premium Fluid. Is this the same?
Old Mar 3, 2008 | 02:37 PM
Kerbbirds's Avatar
I would say yes, I went to my garage and what I quoted is whats on the bottle, at the polaris shop thats what my 700 takes and it doesnt have adc.
Old Mar 3, 2008 | 07:05 PM
sheepdogMSP8117's Avatar
It's not the same. My 500 without ADC takes the regular Premium Demand Drive fluid. My 800 with ADC takes the LT fluid. The regular fluid is green, while the LT fluid is a very light honey color. The LT fluid is for front differentials with friction plates and over-running clutch (ADC). If you search the Polaris forums for "front diff" or "LT fluid" you'll find posts about this from me and SCRAMMYTODD. I've posted pictures as well.
Old Mar 3, 2008 | 08:23 PM
so2315's Avatar
This is just my point. I have looked at the other posts and from what I can gather, If you have ADC you must use the LT fluid.
If you DO NOT have ADC, then you can use either as I have seen where Polaris is getting rid of the regular fluid.
My manual suggests LT fluid, but this is just as confusing as ****!!
Old Mar 4, 2008 | 11:42 AM
I heard that the new 2W-50 oil is going to replace the 0W-40 and 0W-50, but I didn't hear the same about the front diff fluid.
This is what I think about it:
The only difference between the ADC and non-ADC front diffs is that the ADC has clutch packs/friction discs in it. The rest of the internals are the same. So the LT fluid should be able to handle a non-ADC front diff just fine. So the LT fluid is probably backwards compatible, whereas the regular Premium Demand Hub fluid should not be used in ADC front diffs because its not compatible with the clutch packs.
Since the non-LT fluid has been working well for me in my non-ADC 500 for two years now, I'm going to stick with it as long as its available. Matter of fact, I'll probably buy a couple of quarts which should last several years since it only takes 5 ounces per change.
Old Apr 11, 2008 | 10:33 AM
ccolt1's Avatar
I have a 2008 sportsman 500 ho carb model without adc but the manual says lt fluid . Is it ok to use just the prem demand drive fluid in it?Thanks for any help!!
Old Apr 11, 2008 | 10:36 AM
Yes, either fluid will work fine in the non-ADC front differentials.
Old Apr 11, 2008 | 11:08 AM
ccolt1's Avatar
Thank you for the fast reply sheepdog! I am taking to the dealer today to have them look at the leaking front diff.I just want to make sure the use the right stuff. The mechanic said to use that oil and to only use 5 oz.
