Squeaky steering
Old Mar 3, 2008 | 07:53 PM
Forrest1's Avatar
Default Squeaky steering
There is a squeak when steering left and right. The noise does not seem to be coming from the suspension. Does anyone have any ideas of a grease point or where at in the steering I should lube to remove the noise.
Thanks,
Forrest
Old Mar 3, 2008 | 10:54 PM
Forrest1's Avatar
The more I look at it, it is more of a creaking noise then squeeking. It appears to be coming from the front upper arm area. I wasnt able to find any zerk fittings yet, if there are any.
I had a polaris before this one and there were zerk fittings on the arms, but how do you all suggest I grease the arms on a Kodiak?
Thanks,
Forrest
Old Mar 4, 2008 | 12:59 AM
87 warrior's Avatar
if there's no grease fittings than it's a dry lube set up. with out taking it appart and actually greasing it you can spray wd-40 or pb blaster on the moving parts. i did this on my cuz's honda 300ex and it stoped and is fine now. or it could be possible that you need new bushings. but i would spray it with something and see if it stops.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
