Canondale hub keeps stripping??
Old Mar 4, 2008 | 12:24 PM
firehawkws6's Avatar
Default Canondale hub keeps stripping??
Ok, i've got a cannodale moto and the right hub keeps stripping, i've gone through 3 hubs in the past 6 months... the second time i bought a used hub off ebay and the third time i bought a new one and it just stripped out again. The axle splines are in perfect condition, and the crown nut is always tight as a virgins *****... If theres no reasons for this happening, is there something i can do to help prevent the 4th one from stripping out so fast??
Old Mar 4, 2008 | 04:58 PM
WISTECH's Avatar
Do you have enough spacers in the axle. Is the nut bottoming out ? They must be retorqued a couple times as if run looose for any amount of time strippes the splines. Use green locktite on the splines . Not very common to have hub problems but it does happen.
Old Mar 4, 2008 | 05:42 PM
yeah, I have the spacer, and the nut was so tight I had to turn the 1/2 pistol air ratchet to 145lbs. to get it off..I'll try the loctite when my next hub comes in... thanks
tysonbully
Sep 28, 2015 02:30 AM
ny250r
Apr 27, 2001 06:11 PM
Bayou3004x4
Mar 22, 2001 03:20 AM
brokemybanshee
23
Jan 6, 2001 12:37 AM
