2008 Polaris 800 problem
Old Mar 4, 2008 | 10:45 PM
UTU's Avatar
UTU
Default 2008 Polaris 800 problem
My Polaris 800 has about 100 miles on it. When first started up in neutral want to stumble a lil bit. Let it warm up a minute no stumbling in neutral. After I let her warm up to operating temp and gas it from a dead stop want to spit back thru the intake a lil bit INTERMINTLY and not all the time. I can taks off slow till I get to around 2000-2500 and gas it no spitting what so ever. Took it too dealer and he replaced the plugs and adjusted the TPS. I am open for any and all suggestions on where to look now.????
Old Mar 5, 2008 | 08:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did it throw a code at you? is that why they adjusted the t-sensor on the intake? is this the bike w/ the key way in it adjusting the timing? just wondering if would all of sudden have anything to do w/ the computer timing being off? didnt get any water in the tank? howed the plugs look when they replaced them?
Old Mar 5, 2008 | 10:11 AM
RolliePollieOllie's Avatar
My 08 800 behaved similarly and it was a loose negative cable at the battery. Make sure they are tight.
Old Mar 5, 2008 | 12:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that is a good point where these new bikes need a 12.8 volt charge all the time to run correctly.
Old Mar 5, 2008 | 11:02 PM
UTU's Avatar
UTU
No codes. Plugs were black that they replaced.Took timing key out back to stock b4 taking back to dealer.I drained the gas and replaced. This spitting is so intermint???? Checked the battery conection gonna check all the grounds and the positive on the solonoid etc. Im lost if I can not figure out I guess its back to the dealer again????
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
did it throw a code at you? is that why they adjusted the t-sensor on the intake? is this the bike w/ the key way in it adjusting the timing? just wondering if would all of sudden have anything to do w/ the computer timing being off? didnt get any water in the tank? howed the plugs look when they replaced them?</end quote></div>
Old Mar 6, 2008 | 07:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
do you think the the t-bap sensor has got moved and check the connections real good. i was reading the manual about the efi and it says about 80% of problems are due to bad connections on any of the componets. worth a look.
Old Mar 6, 2008 | 07:53 AM
UTU's Avatar
UTU
t-bap sensor? TPS throttle position sensor?
do you think the the <u>t-bap sensor</u> has got moved and check the connections real good. i was reading the manual about the efi and it says about 80% of problems are due to bad connections on any of the componets. worth a look.</end quote></div>
Old Mar 6, 2008 | 12:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no not the tps, thje sensor that sits on top of the intake behind the airbox toward the engine.
Mkp
Mar 28, 2020 03:50 AM
Mphillips
Jul 29, 2015 08:53 PM
TJM
Jun 11, 2015 01:28 PM
RedRancher
Jun 4, 2015 12:29 PM
Schneider
Jun 4, 2015 11:37 AM
