Fuse for accessory outlet
Old Mar 11, 2008 | 09:02 PM
Rowe's Avatar
Default Fuse for accessory outlet
Anyone know off hand what size fuse for the accessory outlet. I have a power inverter and was wondering if the outlet could handle the draw from the inverter. It is 75Watt and has a 15 amp fuse built in. I dont think this would damage anything but not sure. Any advice?
Old Mar 12, 2008 | 12:04 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
The 75 watt is on the 120 volt side.......Is the 15 amp fused on the 12 volt D.C. side?.....................
What do you plan on running with this inverter?
Most ***. outlets should be fused around 20 amp for the D.C. side???
The outlets handle a 12 air compressor well !!!!!
...........Caper..............
Old Mar 12, 2008 | 12:29 AM
RticKwad's Avatar
Runs Stealth!
Anyone know of a portable 12v heater to plug in the accessory plug
for hunting with or w/o an inverter, I do believe I have one of those.
I have been scouting around and haven't found one, this
would work good with my rain rider enclosure for those hunting days.
Cheers,
R'
Old Mar 12, 2008 | 09:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the acces. fuse is a 20 amp fuse. just remember that the alt. only puts out 500 watts @3,000 rpms. this means if you have a heavy power drain, the most you'll get is 500 watts to run the whole bike and the extra's @3,000 rpm's. so if you'll idling the bike chances are your pulling alot less. just a thought
Old Mar 12, 2008 | 11:46 AM
sheepdogMSP8117's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
SNIP
SNIP...........Caper..............</end quote></div>
The "***." should always be an "outlet." [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 12, 2008 | 11:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
lol.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 12, 2008 | 06:05 PM
Unless your at the Doctor's office!!!.....LOL.....LOL............Caper........ ....
Old Mar 12, 2008 | 08:54 PM
Moon Riverrrrrr! LOL!!
Old Mar 12, 2008 | 10:51 PM
upnort's Avatar
Rtic if you go by a decent sized truck stop they have all sorts of 12 volt accessories, heaters included or electric blankets even.
Or do a search for 12 volt heaters, will keep you busy a while.
Old Mar 12, 2008 | 10:54 PM
upnort's Avatar
Assuming about 60% effeciancy will probably draw about 10 amps and I believe has a 20 amp fuse for the *** outlet. So the battery will not last long.
