counter balance oil
Old Mar 14, 2008 | 11:03 PM
big_kid's Avatar
Default counter balance oil
what weight oil goes in thare...
Old Mar 15, 2008 | 12:11 AM
rally's Avatar
10w30
Old Mar 15, 2008 | 10:16 AM
dwhst9's Avatar
Yup, 10x30 works just fine.
Old Mar 15, 2008 | 10:18 AM
xplorerman's Avatar
yes 10w30 is what i use in mine
Old Mar 15, 2008 | 09:27 PM
big_kid's Avatar
10w30 it is then... if the oil went "by-by" and no leaks can be found then where did it go...? thanks
Old Mar 16, 2008 | 01:21 AM
sprinter10's Avatar
how often are you suposed to do this? i got my 1998 400l sport 4 years ago never changed checked it anything runs great. yea i am stupid i thought it was like a motorcross 2stroke and no crank oil and it got lubed from teh oild in the fuel. how much does it hold? how hard is it to drain and change? i did the tranny recently.
Old Mar 17, 2008 | 04:38 PM
big_kid's Avatar
most dont know about it. the dipstick is hidden real good behind the exhaust pipe. the drain is in the bottom of the engine. remove the engine skid plate and its in the center. 10mm socket. i changed all the fluids when i bought this bike 5 years ago and figured id check it and it was empty. but back to my question, where did the oil go if i dont see any leaks, did a seal go bad and the oil get burned in the combustion cycle...
Old Mar 18, 2008 | 07:35 PM
big_kid's Avatar
HMMMM... noone knows...
Old Mar 19, 2008 | 02:11 AM
xplorerman's Avatar
Hello when the balincer seal went on mine it went into the recoil then into the e starter i think i only put 75 cc of 10 w 30 in it i hope this helps
Old Mar 26, 2008 | 01:49 PM
wickedzr's Avatar
Should I use a synthetic 10 w 30 or just regular?
Thanks,
van
