Rear Brake Pedal
Old Mar 15, 2008 | 09:40 PM
Needmoretoys's Avatar
Default Rear Brake Pedal
Hello ...
Anyone have any suggestions on how to get more braking from the foot brake pedal ... Braking is virtually non existent using the pedal...
Thanks
Old Mar 15, 2008 | 09:50 PM
corybowman's Avatar
You will need to adjust the brake system at the brake, their should be a mechanisim right next to the brakeing area that when turned will loosen or tighten the brake response.
Old Mar 15, 2008 | 09:54 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Are you using the pedal all the time.............You should/must use the handlebar lever for braking......Due to the fact this will control all the braking front with the rear!
When the foot pedal is used this will only provide braking at the rear rotors!!!
If you don't know this already........If you do please disregard....Caper........
Old Mar 15, 2008 | 10:04 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its a hydraulic brake there is no adjustment.
Old Mar 16, 2008 | 01:18 AM
Kerbbirds's Avatar
probably needs bled, they do that all the time
Old Mar 16, 2008 | 06:00 PM
Cutty's Avatar
it's a piece of crap, i have replaced my rear master cylinder 3 times
Old Mar 16, 2008 | 06:53 PM
Something wrong then!!!!!............Caper............
Old Mar 16, 2008 | 08:32 PM
sjbr549's Avatar
what year is it? on mine there's a lock nut and bolt to adjust the pedal. where the pedal mounts on the caliper there's a bolt sticking out of the center of the caliper.loosen the nut and turn the bolt it will raise or lower the pedal.
Old Mar 17, 2008 | 12:35 PM
Cutty's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
Something wrong then!!!!!............Caper............</end quote></div>
What's wrong is that those cheapo master cylinders are a piece of crap!!
Old Mar 17, 2008 | 01:39 PM
sjbr549's Avatar
i must of got a good one then as far as i know it's the orginal
