600 sportsman valve noise
I have a 2004 polaris 600 and last week end I got a new noise in the engine. It sounds like pinging valves and there are no adjustments. I use to work on them at a dealer 4 years ago and i never heard this noise. I was just going to get some ideas from others.
I just so happened to change the oil the day before the problem started. Also this happens when the motor is hot and you put some strain on the motor does not do it in neutral. Anybody ever got bad gas that could cause this. To descibe the noise a lttle better it sounds like a two stroke just not as loud. Like i said i have worked on 100s of polaris and never had a quad with this problem. most of engine noise i heard was worn gear train and a couple of cases bad lifter and the bad lifter was more of a tick and a little loss of power. So i am lost and dont want to tear it down and it really not be an interal engine noise.
Mojave250A
Jul 11, 2015 10:38 AM
