Raptor 660 bearings?
Old Mar 20, 2008 | 07:29 PM
ryenol's Avatar
Default Raptor 660 bearings?
Need to replace the crank bearing on the right side(have a hot rod crank already) also need to replace the bearing for the counter balancer(on the right side), and bearing on right side case that is behind the clutch.
What i am wondering is can I get these bearings anywhere else besides yamaha? They seem kinda speny through Yamaha any help is greatly appreciated.
Old Mar 20, 2008 | 07:38 PM
woodsjunky's Avatar
get yamaha its the best for ur machine
Old Mar 20, 2008 | 07:40 PM
woodsjunky's Avatar
what the hell did u do to need both of those berrings, never met anybody who needed the crank and balancer shaft gear?
Old Mar 20, 2008 | 08:05 PM
ryenol's Avatar
The rod broke and dropped off of the crank, somehow didn't damage the cyclinder in any way. The counter balancer was warped, as was the shift drum.
These bearings I have mentioned seem to have a little bit of drag when turning by hand, so I thought it would be best to replace while I am right there.
Old Mar 20, 2008 | 11:23 PM
Raptor450's Avatar
You can get bearings from somewhere else. They are usually the same bearing, just without Yamaha on them. We have a place here in town that specializes in bearings. They also rebuild electric motors, so if you have somewhere like that near you, you may want to check them out. Your old bearings have numbers on them, you will need these to match the new ones. I would be hesitant to install a different bearing on a crankshaft, that's an important bearing. You can start here http://www.bearingplace.com/
Old Mar 21, 2008 | 11:21 PM
ryenol's Avatar
thanks again for the info, I have found a couple of places, one in Muskogee Ok, and 2 in Oklahoma City that are very helpful,
Best of all the 3 bearings that would cost me 90 plus through Yamaha, are 36.00 plus 8 bucks shipping, same bearings cool
2quiker
Mar 22, 2022 08:36 PM
Alex Rodak
Sep 11, 2015 11:42 PM
1ArmBandit
Sep 8, 2015 08:59 PM
black_thunder
Sep 7, 2015 01:24 AM
Elkaholic
Sep 6, 2015 02:44 PM
