cant shift
Old Mar 22, 2008 | 12:49 PM
kenworth's Avatar
Default cant shift
i got a 98 polaris 400 4+4 runs fine goes fine but i cant get the lever to shift for N-L-H-R WHATS WRONG WITH IT
Old Mar 22, 2008 | 02:23 PM
drlang's Avatar
Default cant shift
Is it a gear now?
Old Mar 22, 2008 | 02:33 PM
kenworth's Avatar
Default cant shift
YES IT IS! WHERE CAN I FINE THE VIN # ON IT TOO?
Old Mar 22, 2008 | 02:44 PM
drlang's Avatar
Default cant shift
VIN should be on the right framepost. I believe you are stuck in one gear while the selector is in another. Lets say the machine is actually in reverse and the gear shift is in another spot. You need to force the selector back into the reverse spot before you can proceed. Another way to do this is to remove both shifting rods and put both levers on the transmission in the center position put the gear select in the neutral position. the rods should line back up and away you go. Hope that is your problem. Doc
Old Mar 22, 2008 | 02:47 PM
kenworth's Avatar
Default cant shift
HOW CAN I CHECK THE VIN ON IT HOW MANY NUMBERS SHOULD IT BE THANKS
Old Mar 22, 2008 | 02:50 PM
drlang's Avatar
Default cant shift
Don't know how many #s, But it should start with your year. 98-----
Old Mar 22, 2008 | 03:01 PM
kenworth's Avatar
Default cant shift
ALL IT AS IS MN/W968040 THEN IT AS *2919059* ARE ANY OF THOSE IT SO I TAKE THE GEAR LEVER OFF THEN WHAT I DONT WANT TO MESS IT UP?
Old Mar 22, 2008 | 03:10 PM
drlang's Avatar
Default cant shift
Take the shift rods off, not the shifter. Sounds like it's a 96
Old Mar 22, 2008 | 03:18 PM
kenworth's Avatar
Default cant shift
WHERE ARE THOSE AT
Old Mar 22, 2008 | 04:23 PM
drlang's Avatar
Default cant shift
They go from the shifter to the transmission
