Sportsman Grease Fittings
Old Mar 23, 2008 | 09:07 PM
cnewty's Avatar
Default Sportsman Grease Fittings
How many grease fittings on an 06 Sportsman 500 EFI? I found one for each A-arm, and one at the bottom of each strut on the front. I couldn't find any on the the yoke or driveshaft.
Old Mar 23, 2008 | 09:20 PM
polarisman600's Avatar
did you check your manual? i think it tells you all of them if i'm not mistaking.
Old Mar 23, 2008 | 09:51 PM
hobbles's Avatar
Evenin cnewty
I had to remove my rear tires to get to the ones in the back of mine. You have one on your drive shaft also, You can see it under the quad. There is a 2 or 2 1/2 " hole in the skid plate that will let you get to it from under the left side. Do you have the owners manual? if you do I will dig mine out and sent you the page number,,,
Old Mar 23, 2008 | 10:56 PM
cnewty's Avatar
I do not have a service manual. If any of you have a digital copy that you could email that would be great.
Old Mar 25, 2008 | 10:17 PM
cnewty's Avatar
ok, i found the one on the rear of the drive shaft. Took off my tires and still did not see any on the rear other than the a-arms.
JohnnySplat
Aug 6, 2015 12:07 PM
toonces
Jul 28, 2015 01:58 PM
200es
Jul 10, 2015 09:09 AM
ranvette
Jul 4, 2015 06:13 PM
