Choosing between 2x4 and 4x4
I am trying to decide between a '05 Foreman 500 2x4 and a '04 Rancher 350 4x4. I can't decide if I should get the Rancher because it is 4x4 or not. My brother has a 2x4 Rancher and says that he hasn't been stuck yet, that I shouldn't worry about getting 4x4. I will probably use it for hunting primarily. Any opinions?????
4wd has it's advantages, but a good rider on a 2wd can usually go the same places. You could get the Foreman and add a winch or go with the Rancher and a winch would still be a good option. Or you could just ride with people that have winches.
I have a 450 foreman 4X4. I usually ride in 2wd unless I get into a lot of mud!Now saying that If I didn't have the 4X4 feature I would find another route around the mud or take another trail and the 2X4 would be fine.Unless you are planing on big tires and bad mud I think the 350 has lots of power and it would be my personal choice.If you ride on slippery hills or rocks or in snow the 4x4 will put a smile on your face..
I put Mud Lite on and I'm really happy with them I think there 25" not sure off the top of my head but there pretty much standard size with a real nice tread.I'll try and send a picture if I can figure out how !
The reason I say 26" instead of 25" is that most ATV Tire companies only offer the smaller lugs 3/8" on there 25" and smaller tires,once you get into 26" or bigger they offer there larger lugs with 1-3/8th" hight,, plus 26" gives you that little extra ground clearance under the rear differential.
