04 600sp rear axle removal
Old Mar 27, 2008 | 01:12 AM
Taker's Avatar
Default 04 600sp rear axle removal
can someone please tell me how to remove the rear CV axles on my 04 sportsman 600, is there anything inside the differential holding these in place ? I have everything out of the way just want to make sure there is nothing else holding these .
Thanks In Advance
Taker
Old Mar 27, 2008 | 07:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
theres a cir clip that is on the outsie of the shaft. but it compresses into the shaft when you solide out the cv assembly. the shaft just snaps out. sometimes if they've been in for awhile like yours you need to spray some kind or penrating oil like BP Blaster in around the cv where it goes into the rear end. then after a little wait snap it right out and sometimes it even requires prying on it a little but becareful you dont break the alum. housing.
Old Mar 27, 2008 | 11:59 PM
UTU's Avatar
UTU
^ [img]i/expressions/face-icon-small-smile.gif[/img] I AGREE SOMETIIMES THERE ARE A LIL STUBBORN BUT THEY POP OUT AND BACK IN!!
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
theres a cir clip that is on the outsie of the shaft. but it compresses into the shaft when you solide out the cv assembly. the shaft just snaps out. sometimes if they've been in for awhile like yours you need to spray some kind or penrating oil like BP Blaster in around the cv where it goes into the rear end. then after a little wait snap it right out and sometimes it even requires prying on it a little but becareful you dont break the alum. housing.</end quote></div>
Old Mar 28, 2008 | 06:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just another point, but they dont just pull right out w/ constant pressure as they need a good snap and maybe w/ a pry bar. but i would let it set w/ the penertrating oil for a bit before you even try it.
Old Apr 7, 2008 | 08:22 PM
Taker's Avatar
Iam in the process of removing the rear left CV joint . I soaked it in penetrating oil (wd40) and Ive let it sit about 6 hours and tried pulling , prying , tapping around it with a hammer, I manged to pull the axle out of the cup ,that sits up tight to the housing ,so now I have the CV joint out but the cup is still in the differential and I'm all out of ideas . I guess maybe I'm being to careful not to break the aluminum housing does anyone have any ideas. One more thing the last couple times I have rode it , for the frist little while 4wd drive doesnt want to work in reverse , I push the overirde button in and the dsiplay says the 4wd is working but only the rear wheels are spinning after playing with it a bit i can get them to lock in then after 5 mins I have to play with it again, to get it in 4wd in reverse again, after I do that a couple times its normally good for the rest of the day and it works good. Thanks for everyones help
Taker
Old Apr 7, 2008 | 09:41 PM
UTU's Avatar
UTU
I had to get a slide hammer puller when my son broke his front axle. Leaving just the short axle in differental.Takes a good snap to get it out.
Old May 18, 2008 | 12:55 PM
cadboy1's Avatar
I had the same problem on my 03 700. I have the cup still in the rear. I pulled and pryed for a hour and it would not budge.
Old Jun 5, 2009 | 05:53 AM
snowpacker's Avatar
ok i have a buddy having same problem trying to get cv joint out of rear end wondering if he can take off other side to see end of bad cv joint shaft. thus be able to use a punch to push out bad cv joint shaft?
Old Jun 5, 2009 | 06:26 AM
chuck_raduenz's Avatar
i looked at a diagram. and it apears to be hollow, and it might work.
Old Jun 5, 2009 | 06:30 AM
but the rear gear cases on your and his are differnt. his is thiner and your i beleve is fatter. so i dont think it would work on your to pull the oposite side out and try to pund it out. his it looks like its just a large gear with splins go all the way though.
