07 wolverine carb/jet question
Old Mar 29, 2008 | 03:27 PM
tarac's Avatar
Default 07 wolverine carb/jet question
hey guys my dad has an 07 wolverine. hes not too good with computers so he wanted me to ask how to take the carbs off and put the jets in the carbs. so if anyone knows where there is a write up, or if you can give step by step instructions, id really appreaciate it.
thanks
Old Mar 29, 2008 | 03:56 PM
hondabuster's Avatar
Theres no reason to rejet,unless the motor has been modified like an aftermarket exhaust has been installed, or the air box lid has been removed. Just putting in bigger jets, without an increase in air flow, will actually make things worse.
Old Mar 29, 2008 | 04:25 PM
tarac's Avatar
yeah aftermarket exhaust has been installed.
trust me he knows what hes doing, no advise is needed only the instructions. thanx
Old Mar 29, 2008 | 08:56 PM
ctateusa1's Avatar
ok as far as replacing the jets it can be done with the carb on the bike but its kind of a PITA.
I just loosened the two clamps on the carb boots and twisted mine, because i didnt want to have to remove my throttle and choke cables all the way.
Removed the 4 phillips screws, pulled the float bowl off. And then took a slotted screwdriver and removed the jets and replaced them.
Old Mar 31, 2008 | 01:03 PM
tarac's Avatar
sounds good. thanks for your help.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
