Fool the Raptor CDI for more revs in reverse?
Old Apr 1, 2008 | 08:08 PM
audiobill5's Avatar
Default Fool the Raptor CDI for more revs in reverse?
On a stock 04 660R, is there a cheap way to raise the rev-limiter rpm maximum for reverse? Thanks
Old Apr 2, 2008 | 12:57 AM
Quad-Maniac's Avatar
Ground the green/white wire that goes to the reverse switch (below the output sprocket). This prevents the CDI from seeing that you're in reverse and so the limiter never gets turned on. The reverse light also stops working.
If you want, you can add a toggle switch that when turned on grounds the green/white wire, eliminating the limiter; but when turned off, returns to normal limiter and light operation. You would then use this switch as an 'override' of the limiter.
Old Apr 2, 2008 | 08:50 AM
audiobill5's Avatar
Thanks Quda-Maniac!
Last night I thought of calling Yamaha for the info: I may as well beat my head against the wall, I'm sure the FEDS made them do the rev limits!
I sure do appreciate the input and the time you spent to help out this newbie!
Sure hope I can return the favor some way, some day...Bill.
Old Apr 2, 2008 | 01:55 PM
hondabuster's Avatar
Make sure to wire it thru a switch. You never know when a kid or newbie is gonna take it for a spin, and youll want the low rev limiter in there for them.
Yamaha wouldnt be able to tell you about this "fix", nor can dealers.
Njrider1230
Jul 29, 2023 05:16 AM
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
house1
Aug 9, 2015 10:49 PM
Schneider
Jul 24, 2015 05:05 PM
