Motor Bogs Down @ High RPM
Old Apr 5, 2008 | 01:17 PM
smokef16's Avatar
Default Motor Bogs Down @ High RPM
2000 Polaris 500 Sportsman, starts and runs fine, but when I try to accelerate it bogs down and backfires like when you use reverse without pushing the overrride button. Plug looks good, fuel looks good, air filter looks good, anyone ever had this issue?
Old Apr 5, 2008 | 04:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe the cam lobs are worn. on the older yr 500's some had the cams wear on then making them run crappy. just an idear.
Old Apr 5, 2008 | 11:09 PM
ftwflh's Avatar
Before going to the cam check the secondary buttons
Old Apr 5, 2008 | 11:39 PM
Kerbbirds's Avatar
Also make sure the ETC is adjusted correcly , about 4 inches from the thumb throttle adjust slack so there is only 1/8 of an inch.
Old Apr 7, 2008 | 01:34 AM
smokef16's Avatar
ETC works fine, thanks, what are the secondary buttons?
Old Apr 7, 2008 | 02:05 AM
UTU's Avatar
UTU
On the secondary clutch (Driven) Check the clutch belt too!
Old Apr 7, 2008 | 11:42 PM
vinman18's Avatar
my 98 trailboss is starting to do that but it is only when i push the throttle half or more and it will do it when i have it in nuteral and i rev it up. is sounds just like you described. i think it seems like an exaust leak but my brother tells me it might be a bad spark plug. i still have to cheak a few things
Old Apr 9, 2008 | 07:09 PM
cchucky51's Avatar
i have had same thing with my 250 have been tring to find the cause for 3 weeks, have rebuilt the carb 3 times,cleaned the gas tank filters, checked the plug checked the air tubes, checked spark even went as far as putting a rubber hose over plug wire thought it was arcking, i have changed the fuel filter but i have notcied went it dsoe act up there is air bubbles in the fuel filter, mine works some times and others it won't so if some finds the answer please pass it on
Old Apr 9, 2008 | 08:00 PM
bullpark1956's Avatar
SMOKEF
Check the vaccum diaphram i have seen many with small pin holes in them and causes this alot,take it out hold up to lite and look very careful,ive had a couple that couldnt find the hole but changed the diaphram and poof it ran like new again just my 2 cents
Old Apr 9, 2008 | 11:41 PM
smokef16's Avatar
bullpark1956
do you mean the one inside the carb? I changed the belt, cause it was a little thin (according to the book) with no change. i guess i have a spare now. my next step is to check the gas. i also noticed it's running a little hot (the fan comes on more often and sooner than before). this may be related, so i'll probably ask the local mechanic if this sounds like anything he's encountered before. just don't want to bring it in (pride, puzzle,$$$, etc.)
