Buying a new DS-650 problems
Old Apr 7, 2008 | 12:24 AM
Lhduce's Avatar
Default Buying a new DS-650 problems
I went to check out 06 ds650. i believe the bike has been roll over since the back bar is bent some also i notice the stem was bent. Anything else to look for before i buy it also how much is a new stem? the guy says the bike has 10 hours but im sure it has more..Im not going to lie im very worry about buying this bike. Even you know its a great price. Any help guys would be great..
Old Apr 7, 2008 | 12:33 AM
450x's Avatar
if your worryed about the bike i wouldnt even waste ur time on it just keep lookin around/savin up, it could become a head ache when **** starts fallen off
Old Apr 7, 2008 | 12:37 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
First how much is he asking and whats the general condition beyond the bent stem.And if a ds was rolled the stem is easily bent its a heavy pig.No biggie if thats the only problem.and somewhere in the 250 range to fix a stem.But the rule of thumb is if you don't feel good walk away.......[img]i/expressions/face-icon-small-wink.gif[/img] Me or no one on here can second guess your first impressions of the guy or the deal.
Old Apr 7, 2008 | 12:00 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
True, True, True, I agree with everything AZ said. And if the only problem is the bent bars and stem, no big deal. I've rolled mine 3 times at the dunes and I replaced my bars and all is well. Good luck!
Old Apr 7, 2008 | 02:41 PM
Entomber's Avatar
Motor may be sound... but check for leaks. A roll over doesn't really damage the motor. Check chain if it's rusty shows sign of negligence on his part. Chain maintenance tells you a lot of the previous owner. See if you can take it for a spin, observe hwo easily it shifts into every gear. When firing it up take note on how easy it starts (try to start it from when its cold) and observe any smoke coming from exhaust. They are solid bikes.. but as stated you feel the deal is too good to be true.. it probably is.
Old Apr 7, 2008 | 05:41 PM
Majorecho's Avatar
if the stem is bent , the headlight most likely has broken tabs too.
Old Apr 8, 2008 | 04:41 AM
Lhduce's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Majorecho
if the stem is bent , the headlight most likely has broken tabs too.</end quote></div>
this is true the headlight was bent down..
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
ranvette
Jul 4, 2015 06:13 PM
DTroyer01
Jul 3, 2015 07:34 AM
