Cluch Roller!!
Old Apr 14, 2008 | 06:11 PM
maddog24's Avatar
Default Cluch Roller!!
Before i do this Mod How many Grams should i have?
Polairs Haweye 300 Yr 2007 (23" wheels on the bike ) I do not have the stock 22" tires. I hered i need abt 98-grams total.
Stock Roller are 13-grams ! i have bought a set of 11-grams roller.
Can i use (4) 13-grams & (4) 11-grames 96-total grams, or do i have to have all the same size roller in to make it balance out right ?? Thanks for any feed-back
Maddog24
Old Apr 14, 2008 | 06:25 PM
TennesseeTider's Avatar
Why not send back the 11g rollers and get some 12g rollers? I put 12g rollers in mine and like it. Mine came with 14g rollers, though.
Old Apr 14, 2008 | 06:43 PM
maddog24's Avatar
Thanks for the suggestion, but my dealer told me that 11-grams roller were the only rollers he could get me!! Plus i am thinking if i put bigger tires on later down the road, i might need all 8 of the 11-gram rollers.
Maddog24
Old Apr 14, 2008 | 10:25 PM
jokout's Avatar
maddog, when I first did the roller mod I simply removed two opposing 14 gm rollers leaving 6-14 gm rollers for a total roller weight of 84gm and I had the 25" Swamplite tires on that actually measure 26". In my opinion I thought this was a bit to much to remove, the engine seemed to be overreving a bit and it would run out of power at the top. While it just might have been my imagination. it seemed to pick up a bit more vibration with the two rollers missing, I just wasn't comfortable with that setup.
I then put in all eight of the 12 gm rollers for a total weight of 96gm and this seems to match the power curve of the engine more closely and makes the engine MUCH happier from launch all the way up to about 45-50 mph...
Old Apr 14, 2008 | 10:30 PM
jokout's Avatar
Maddog, tell your dealer to order part #5412987, those are the 12gm [High Elev.]rollers for the 06 Hawkeye they will be red
Old Apr 14, 2008 | 11:19 PM
maddog24's Avatar
Jokeout, Thanks for all the Info, It sound's like 96-grams is what i need to do!!
Old Apr 14, 2008 | 11:38 PM
jokout's Avatar
seems to be the sweet spot for mine...oops..the wifes!
bvandass
Oct 8, 2015 09:13 AM
Polaris5
Aug 29, 2015 09:11 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
JohnnySplat
Aug 6, 2015 12:07 PM
clsharky
Jul 13, 2015 02:07 PM
