94 300ex main jet location?
Cleaning carb, and took both jets out. Main with adjustment, how far? Screw in till stops and tighten lock nut? back off...? Just picked this thing up. Has a FMF pipe and UNI filter, would that affect jet location?
thanks for anything
thanks for anything
All jets get snugged up, non are backed off. Youre thinking of the mixture screw, which should end up about 2.5 turns out from bottomed.
The pipe will probably lean it out a bit. The filter shouldn't change the breathing side, from what the stock filter was.
Thanks guys, put it all back together and fired right up. Have manual coming from guy i bought from, just don't have it yet. Think it needs solenoid?, right off battery, can jump this and start. Also they have a toggle swith in lieu of ignition which doesn't work. Has a UNI, and Power core 4 exhaust. Also has a steering stabilizer.
thanks again.
thanks again.
Oct 10, 2015 10:20 AM
