kfx 400 steering
Old Apr 15, 2008 | 10:26 PM
clutchoo7's Avatar
Default kfx 400 steering
i have an 05 kfx400,sunday i was riding and stuffed the left front end in a ditch,hard enough to the side to throw me off.now when i ride the machine it pulls to the right.i looked at th a-arm and tie rod. both are fine.the shock seemed to be stuck in position,i have freed it up since.is it possible the ball joint could be the problem?thanks for any info.
Old Apr 16, 2008 | 03:18 PM
DrRandall's Avatar
http://forums.atvconnection.co...atid/9/threadid/541000 check my topic out
looks like we're having the same kind of problems. I would say that you should replace the ball joint first, then go from there.
Ball joint, Shock, Tie Ride, then the A-arms if needed. Hope that helps
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
