what do i do
Old Apr 16, 2008 | 02:21 PM
nightmare0098's Avatar
Default what do i do
how do i tighten the chain on a 2003 blaster 200?? i tried the two bolts on the back but it didnt do anything
Old Apr 16, 2008 | 03:27 PM
P1FOXRIDER's Avatar
ok, you have two long bolts going through both hubs, one on the top, and another on the bottom, loosen them both up (they are either 17mm or 19mm, i cant remember), then back out the two small bolts (make sure they stay even), then wiggle the bottom back, it will kind of roll forward on the top as the bottom slides, set it where you want it and tighten it all back up
Old Apr 17, 2008 | 02:15 AM
i tried all that and it is still loose.. doesnt look or feel like it even did a thing...
Old Apr 17, 2008 | 09:31 AM
P1FOXRIDER's Avatar
loosen u thse two big bolts, bacj the smale bots out, and roll the qaud forward, that should cause the rear axle two slide backward, if not spray down everything with some wd-40 to help it loosen up
Old Apr 17, 2008 | 03:43 PM
thanx for your help mang..
but i bought a new chain today. problem solved. lol
