05 660 Raptor bogging
Old Apr 16, 2008 | 06:38 PM
habitatjoiskater's Avatar
Default 05 660 Raptor bogging
it keeps bogging out when i hit the throttle and i just put 20 50 in it but it ran bad before that. gas is full and what not and idk what thickness oil i should be using and its about 60-70 degrees out so no clue.
everything that i have on it is under here. how would i adujust the time and check the valves or whatever you need to do with the hotcam stage 2
Old Apr 16, 2008 | 07:42 PM
P1FOXRIDER's Avatar
could be running fat, pull the needles out of the carbs and (if there is enough adjustability) go up two notches with the e-clip
Old Apr 17, 2008 | 01:02 PM
will do
Old Apr 17, 2008 | 06:22 PM
idk i shouldnt have to jet it cuz when it idles it goes up fine but when im driving it starts to bog so i dont know but i will bring the carbs out later
Old Mar 7, 2009 | 12:18 AM
Slaayer's Avatar
I have a 02 raptor 660 that is doing the same thing I have rebuilt the carb put another carb on rebuit it, adjusted valves, oil change, air filter, new cdi, new pick up coil an stator. the quad starts an runs like a champ you can even ride it down the road but when I accelerate it pops an bogs out head is tight, carb boots are good, new gas....help
Old Mar 7, 2009 | 08:57 AM
91Warrior357's Avatar
i think raptors have some weird reverse sensor or something and when this gos bad it causes the problem your having, maybe check into that i cant member exactly the details on it. 20-50 is pretty heavy stuff i usually use 10-30 10-40 or 15-40, and i never use the same oil cars use only JASO approved motorcycle oils.
bmxatv10
Oct 14, 2022 06:23 PM
Sassinm1
Sep 30, 2015 04:23 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
