Help,need jetting help old big red
Old Apr 19, 2008 | 11:22 PM
mrtool2u's Avatar
Default Help,need jetting help old big red
My dad has a old (1982) Big Red that he putzes around on and he is having a terrible time fouling plugs. It has a 90 main in it now,,how lean could we safely go. I have the clip the whole way on top groove. Also,the air mixture screw,I assume turned out is leaner. Any help much appreciated.
Old Apr 20, 2008 | 01:16 AM
hondabuster's Avatar
Out is richer, on mixture screws.
Does it burn oil? Hows the compression?How dirty is the air filter? Float level check out ok?
Id go to an Iradium spark plug, before going leaner on the main jet. They are designed to resist fouling much more than standard plugs.
The needle jet is set at the leanest when the clip is at the top...id go back to the center.
Old Apr 20, 2008 | 08:48 PM
mrtool2u's Avatar
Not to question your wisdom,,but out is deffinetly richer on air screw. It seems to not burn oil,,like I said,it is my dads and it gets run very seldom. Air filter is clean,compression is good,float seems ok,what Iradium plug should we go with. It currently has a NGK dr9es in it. You can go a couple hundred yards and the plug is black. I know the air screw was 2 1/2 turns out,he thought that out was leaner.
Old Apr 20, 2008 | 09:33 PM
snorulz's Avatar
I have 2 84 200es big reds that had the exact same problem. All i did was adjust the pilot screw and leaned them out some. I would go through 1 plug per week of ridding. I haven't had to change a plug since then and this was done over a year ago.
Old Apr 20, 2008 | 10:43 PM
<div class="FTQUOTE"><begin quote>Originally posted by: mrtool2u
Not to question your wisdom,,but out is deffinetly richer on air screw. It seems to not burn oil,,like I said,it is my dads and it gets run very seldom. Air filter is clean,compression is good,float seems ok,what Iradium plug should we go with. It currently has a NGK dr9es in it. You can go a couple hundred yards and the plug is black. I know the air screw was 2 1/2 turns out,he thought that out was leaner.</end quote></div>
Its a 4 stroke, which 99% are mixture screws. If the screw is between the slide and the cylinder head....its a mixture screw.
If its between the slide and the air filter....its an air screw.
And on air screws....out is leaner.(just the opposite of mixture screws)
Make sure all the components are on the mixture screw..spring, steel washer, and o ring.
Old Apr 21, 2008 | 12:44 AM
Gimpster's Avatar
The problem with the old big red is not jetting.
The needle jet and jet needle need replacement.
After years of use, the brass components wear from the needle rattling around.
Go to your Honda dealer and have them sell you a needle jet set.
The carb will have to come apart to replace the needle jet as it rides under the main jet emulsion tube. When installing, make sure the thin walled side is inserted towards the carb bore. The jet needle is easy to remove as it simply slips into the throttle slide under the spring and plate.
Later year units have aluminum needles that fit the slide better and will not shatter out.
----- Gimpster -----
Old Apr 21, 2008 | 09:46 AM
Ujoint's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Gimpster
----- Gimpster -----</end quote></div>
I agree with Gimpster - BUT - you can get a whole aftermarket carb kit (with everything but the float) for less than the cost of the 2 components from your dealer ($38 honda needle jet set vs. $15-20 for Keyster, Shindy, Armor Tech complete kit). Ebay or your Local independent ATV repair shop will be your best bet.
Old Apr 21, 2008 | 02:12 PM
Gimpster's Avatar
Thanks for the added source info my friend !!
Old Apr 21, 2008 | 09:51 PM
snorulz's Avatar
so did my fix not really fix it then? My plugs have looked perfect since i did it and the machines run great.
Old Apr 22, 2008 | 10:16 AM
Ujoint's Avatar
snorulz, Your "fix" was probably fine for your situation - what you did was adjust your idle circuit fuel flow to compensate for the wear on the needle and jet that was allowing a little "extra" fuel. Mrtool2u had already dropped his needle as far as it would go, indicating the total wear on the needle jet set.
