1999 Scrambler 400 4x4 wont idle
Old Apr 23, 2008 | 04:21 PM
JoePitt83's Avatar
Default 1999 Scrambler 400 4x4 wont idle
i hope somebody can help me! my carb is clean and the idle adjustment is all the way in and it still wont idle. has new topend. also what do i have to do to disconnect the oil injection? thanks for helping me.
Old Apr 23, 2008 | 08:54 PM
PoLaRiS RuLeZ's Avatar
What you could try to do is make sure the spring is around the idle screw and if so dont keep adjusting the idle because you will ware down the sring and mess up your idle and try to just start it and leave the choke on for about 3 min but dont leave it while it isnt running because you dont want to flood the engine
Old Apr 24, 2008 | 08:56 AM
JoePitt83's Avatar
the idle screw is all the way in and it is new , but if i choke it shuts off. Are these atvs fast?
Old Apr 24, 2008 | 09:08 AM
Ujoint's Avatar
If it runs fine, but won't Idle - try adjusting your throttle cable at the thumb control (screw the cable outwards) - the ETC may be kicking in. Make sure you back your idle adjustment screw on the carb back out.
Old Apr 25, 2008 | 01:10 PM
JoePitt83's Avatar
i rebuilt the carb and its fixed but the throttle is hanging up wide open.
Old Apr 30, 2008 | 10:06 PM
JoePitt83's Avatar
alright the bike runs awsome , idles smooth , rebuilt carb , but now fuel leaks out of the carb as soonas you shut the bike off. can you adjust the floats , what should i do?
Old May 1, 2008 | 12:17 AM
tbsleeper's Avatar
is it leaking out of one of the places where your suppose to have the overflow hose? dont know where else it would leak...
Old May 28, 2022 | 11:17 AM
Himmm's Avatar
Yeah They are pretty quick man. 400 2 stroke is alot of engine.
Old May 28, 2022 | 11:20 AM
Himmm's Avatar
I've got the same problem. I've been messing with it for days still leaks better than it was but, still leaks
scram5050
Aug 30, 2024 01:39 PM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
sleepyva
Sep 2, 2015 06:32 PM
scram5050
Aug 19, 2015 02:19 AM
