Rough running X2
Old Apr 23, 2008 | 05:34 PM
sricks's Avatar
Default Rough running X2
My 2007 500 HO X2 recently started running rough at idle and ocassionally dies. Unit only has about 350 miles on it. Other times, it will run fine. Any ideas where to start?
Old Apr 23, 2008 | 08:57 PM
PoLaRiS RuLeZ's Avatar
Yea take a look at the idle screw by the carbarator and turn it one turn clockwise and see if that helps or get back to me.
Old Apr 23, 2008 | 10:14 PM
jbbooks's Avatar
More likely than not, your throttle adjuster is loose and needs to be re-adjusted. You have an efi, you do not have a carb. There is a cable that is attached to the thumb throttle. follow that cable a few inches towards the headlight pod. Now pull back the rubber sheath that is over the little bulges in the cable. Here you will find the cable adjuster.
Old Apr 23, 2008 | 11:09 PM
reno82's Avatar
What jbbooks says. I don't know why the dealers don't show this to new buyers, every new Polaris will have to adjust this cable within a few hundred miles. I did on both my 2007's while out on a trail. The owners manual will cover this, it's real easy, if you have ever had to adjust the brake cable on a bicycle it's the same type system where the wire gives over time and you have to make it longer.
Old Apr 25, 2008 | 02:11 AM
X-man's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jbbooks
More likely than not, your throttle adjuster is loose and needs to be re-adjusted. You have an efi, you do not have a carb. There is a cable that is attached to the thumb throttle. follow that cable a few inches towards the headlight pod. Now pull back the rubber sheath that is over the little bulges in the cable. Here you will find the cable adjuster.</end quote></div>
X2 (pardon the pun!) I've got the '06 model and I had the same thing happen right about the 300 mile mark with my X2. Adjusted the throttle cable and haven't had a hitch since.
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
