wires from overide
Old Apr 23, 2008 | 10:08 PM
dogspower1's Avatar
Default wires from overide
hey i bought a 95 xplorer 400 and every thing seems to work but the overide switch got to looking a found the purple wire has been cut but i cant find where it goes to does anybody have any idea that may help could be ground or hot
thanks for any help
Old Apr 24, 2008 | 07:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
guessing but maybe to the tranny switch or the awd button?? does awd work in reverse w/out the override pushed?
Old Apr 24, 2008 | 08:59 AM
dogspower1's Avatar
no reverse awd and the rev limiter works and pushing the button does nothing
thanks
Old Apr 24, 2008 | 09:01 AM
Ujoint's Avatar
The purple wire is the wire that is used to indicate the Reverse position from the gear selector switch. When in Reverse, this wire has power, goes to the Override button - and if Override is not pressed, feeds into the Green wire to the RPM Limiter (Reverse Limiter)....
If the Override is pressed, it releases the Green wire contact to the RPM Limiter and makes connection to the Gray/White wire which feeds your power to the AWD system while in Reverse.
Old Apr 24, 2008 | 10:19 AM
dogspower1's Avatar
thanks so i need to find the wire comeing from the gear switch that has power when in reverse and hook the pur. wire with it on the wire board
thanks
toonces
Sep 5, 2015 01:14 PM
quickwhips
Sep 2, 2015 06:53 AM
Adrian Turner
Aug 30, 2015 04:08 PM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
