Tie rod relocation
Old Apr 26, 2008 | 10:54 AM
06sportsman450's Avatar
Default Tie rod relocation
I have an 06 Sportsman 450 , just bought a set of Mud Bugs 28/10-12/12 and a set of ITP Delta stell wheels with a 4+3 offset . The front tires were rubbing off of the tie rods so I flipped them to the bottom of the mount . Will there be any problems doing this , has anyone else done this , please advise
Old Apr 26, 2008 | 01:03 PM
tstroker's Avatar
reset your toe out and you might be very pleased with the results.
Old Apr 26, 2008 | 03:40 PM
Thanks for the response I just finished adjusting the toe , have you tried this if so more input would be appreciated . I am getting little response form other sites and it seems no one has experience with this so please chime in if you can
Old Apr 27, 2008 | 12:37 AM
sprinter10's Avatar
we did things like this with teh cars without a problem we just made shure that the suspention going up and down didn't bind up the steering.
Old Apr 27, 2008 | 08:28 AM
tstroker's Avatar
lowering the outer improves the bumpsteer, which is bad on a polaris, by bringing the angle of the tie rod and the control arm closer to the same plane. setting up front steering on anything is a real pain, and IMO, polaris isn't very good at it, but as i said it can be improved somewhat. if you want to get a good book on suspension try steve smith's on building a stock car for circle track racing, simple terms, great info.....stroker
MikeyBoyesq
Sep 22, 2015 10:02 AM
switzomatic
Aug 24, 2015 12:57 PM
Cantbuytime
Aug 17, 2015 06:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
