Lift kits for bayou 220
Old Apr 26, 2008 | 09:25 PM
coode_breaker's Avatar
Default Lift kits for bayou 220
Does any body at all know where people can get lift kits for a bayou 220 because i cant find any. and i was also wondering if you can make tha a-arms longer and get an axle or something. bayou 220s are almost unstoppable but come up short on ground clearence cause its not enough
Old May 21, 2008 | 11:51 PM
Mudrunnin220's Avatar
I lifted the front of my 220 by removing the lower arms and making four U shaped brackets out of 1/8" steel that extended just past the frame. I bolted two brackets in front and two in rear. The shock brackets had to be made longer and the inner tie rod mount had to be lengthened. This gave me about 2.5 inches of lift.
A 25" tire fits with no problem but would not sugest putting that size tire on untill eng. work is done. If any questions let me know.
My 220 has a snorkle, eng. modifications, 25" mudlites, 2.5" lift in front.
Old Sep 24, 2019 | 11:05 AM
Evans_dad's Avatar
Default DIY lift you did for your bayou 220
Hey mudrunnin, I was wondering if you could send me some pictures of the U shaped brackets you fabbed and the upper shock mount? I am assuming you had to had to get longer tie rods too? Or did you widen that connection point also? Any help is appreciated.
D
Jatho652
Apr 7, 2018 01:47 PM
freeatvrider
Aug 5, 2005 12:10 AM
Nathan Poe
Apr 26, 2004 08:24 PM
matthew220
May 27, 2002 07:42 PM
