help with 86 trailboss
Old Apr 27, 2008 | 06:39 PM
s7jstep1's Avatar
Default help with 86 trailboss
anyone know where i can get replacement parts for my 86 trailboss? i have tried ebay but havent found much. i mostly need a fuel shutoff valve and a fuel tank. i also would be interested in a new carburetor and a few other things but the valve and tank are the most important. thanks
Old Apr 27, 2008 | 11:23 PM
ftwflh's Avatar
On your tank any 1986-some 1988s will fit.Any 250 carb will work.
Old Apr 28, 2008 | 12:02 AM
Ujoint's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
On your tank any 1986-some 1988s will fit.Any 250 carb will work.</end quote></div>
If you use a later model carb, you will need to continue to use the carb cap that came with your original carburetor - throttle cable changes between early and later years will not accommodate cap changes - - the best thing to do, though, is to upgrade your throttle cable to the later models, and use the later model carb cap (later model throttle cables are WAY cheaper, especially since the early model throttle cable is only available thru Polaris)
Those old tanks were pretty much crap after they got some age on them - I would guess that yours is probably leaking in the indentions where the Polaris logo would be on the sides???
Old Apr 28, 2008 | 03:09 AM
s7jstep1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Ujoint
Those old tanks were pretty much crap after they got some age on them - I would guess that yours is probably leaking in the indentions where the Polaris logo would be on the sides???</end quote></div>
yes it had a crack in that exact spot and i fixed it with a riveted-on piece of sheet metal and some fuel-safe silicone. it looks pretty bad and if i can find a whole new tank, i want to get it. my top priorty right now is to get a new fuel shutoff valve because my old one broke. right now i have all the gas drained and no valve on the quad so that is whats keeping me from running it right now
Old May 5, 2008 | 01:44 AM
s7jstep1's Avatar
well, now the gas tank is completely useless. a crack spread from one rivet to another all the way around the patch and now there is a huge hole where the patch used to be. any ideas where i can get a new one?
Old May 7, 2008 | 03:24 AM
s7jstep1's Avatar
well i found a tank on ebay. it says its off a 87 but it should fit right? it also has the fuel shutoff valve attached. i figure if i can get it for under $100, its worth it considering this is the only one i have found. right now the bid is like $7 + $28 s&h
Old May 7, 2008 | 07:48 AM
ftwflh's Avatar
That one will work.But it will go very high.Be sure to ask if it leaks and the valve is good.
Old May 13, 2008 | 02:16 AM
s7jstep1's Avatar
well, ive been busy the past couple of days and i completely forgot about the auction. it sold for 62 dollars plus 28 dollars shipping. any other ideas where i can get a tank? there is a atv and motor cycle salvage place about 35 miles north that i can go to but he says he doesnt come across the older trailbosses very often.
Old May 20, 2008 | 03:02 AM
s7jstep1's Avatar
well i still have no tank so it looks like im going to put a non-op on the thing and forget about it for now. i did get me a job so maybe soon i can buy the things i need for it
Old May 20, 2008 | 07:58 AM
ftwflh's Avatar
keep an eye out on ebay 86-some 88s will work.Be patient and you will find one.
