Engine swap
Old Apr 28, 2008 | 03:28 AM
bds86's Avatar
Default Engine swap
I was woundering if you could take a 400 engine and swap it out with like a 500 or 600. My engine on my 400 locked up and needs replacing. I didnt know if this was possible.Let me know your ideas. Or if you know where i can find a new engine.
Old Apr 28, 2008 | 10:57 AM
sheepdogMSP8117's Avatar
Default Engine swap
A 500 maybe, but not a twin.
Old Apr 28, 2008 | 03:15 PM
bds86's Avatar
Default Engine swap
Do you think I would have to change anything besides the engine and carb? Wiring, electronics etc...
Old Apr 29, 2008 | 06:12 PM
Spman 800's Avatar
Default Engine swap
LITTEL BIT OF THAT STUFF WOULD BE WORED ABOUT THE 500 FITTING
Old Apr 29, 2008 | 07:36 PM
SCRAMBLER500XXX's Avatar
Default Engine swap
is the 400 2 or 4 stroke, if it is 2 stroke almost none of the engine electronics will work, sorry.
Old Apr 29, 2008 | 10:04 PM
sprinter10's Avatar
Default Engine swap
i have a polaris sportsman 500 engine in my atv it came with a 500 H.O and the prev owner had ploblems kpping teh front end down in trails with major hills and rocks and he has a sportsman 500 that was to sluggish for him so he swapped and i have a sportsman engine andcarb. its the 34 carb the scrambler has a 40 or something idk i think the engines are suppost to be the same on both atvs that are 500 but the H.O. put out alot more power. i hope everything works out for you it would be cool if you could fit a twin in that.
Old Apr 29, 2008 | 10:10 PM
sprinter10's Avatar
Default Engine swap
<div class="FTQUOTE"><begin quote>Originally posted by: sheepdogMSP8117
A 500 maybe, but not a twin.</end quote></div>
anything is possible if you know how to fabricate and have money. ive seen videos on teh web of people putting 4 cylinder snowmobile engines into scramblers and sports. and they fly!!!!!!!!!!!!!!
Old May 7, 2008 | 04:05 PM
user493's Avatar
Moto Psycho
Default Engine swap
As far as I can tell, the four-stroke 425 that they call a 400 is built on a 500 block with a little bit smaller bore and stroke. I've seen them parked side by side and looked real close and didn't see any difference.
Old May 7, 2008 | 05:54 PM
Kerbbirds's Avatar
Default Engine swap
If its a 400 4 stroke the 500 4 stroke will bolt right in , they are based on the same motor the 500 has a longer stroke and bigger bore, if its a HO motor you will need the 40 mm carb and boots instead of the 34mm one.
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
