battery
Old Apr 28, 2008 | 11:38 AM
dxbrobe2's Avatar
Default battery
dose any one know if you have to have a battery inorder for the fan to run on a 96 scrambler my fan is not ingaging but before i start tearing things apart I want to know
Old Apr 28, 2008 | 11:42 AM
atv gooroo's Avatar
Default battery
I beleive so and I also think the AWD will not work.
Old Apr 29, 2008 | 07:23 PM
MECHANIKE's Avatar
Default battery
without your batt your charging system goes wide open+stays there eventually frying wiring+everthing electrical,depending on design,i know someone who started his bike on fire.
Old Apr 29, 2008 | 09:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default battery
the newer ones you would need it for sure and i would guess the older one would want at least some battery in theree or i agree it will take out the electronics for sure.
Old May 7, 2008 | 03:35 PM
user493's Avatar
Moto Psycho
Default battery
One of my owner's manuals said that if you run a quad without the battery it can blow out lightbulbs and I don't know what else. All that electricity has to go somewhere if it's not charging the battery.
Old May 7, 2008 | 11:53 PM
jokout's Avatar
Default battery
Maybe I'm missing something here but you have to have a battery of some sort to complete the electrical circuit.
I'm not so sure that the battery has to be in perfect working order though, I was under the impression that only the newer ECM equiped models had to have a perfectly good battery to keep everything running correctly...but I could be mistaken on this one.
Old May 8, 2008 | 02:50 AM
user493's Avatar
Moto Psycho
Default battery
<div class="FTQUOTE"><begin quote>Originally posted by: jokout
I'm not so sure that the battery has to be in perfect working order though, I was under the impression that only the newer ECM equiped models had to have a perfectly good battery to keep everything running correctly...but I could be mistaken on this one.</end quote></div>
You can short the batery cables to complete the circuit without a battery, but all the voltage that should be chaging the battery will go to your lights and other electrical parts instead.
Old May 8, 2008 | 12:11 PM
TLC's Avatar
TLC
Default battery
The older models can run fine on a dead battery. My Battery was shot for a month before I got around to changing it, I just pull started the ATV and everything worked. I think the newer ECM (2004.5 and newer) models need a working battery though for the ATV to operate properly.
Kinda of a dumb improvement, a cheap ATV battery takes a dump and your walking or getting towed?
Old May 9, 2008 | 12:47 AM
user493's Avatar
Moto Psycho
Default battery
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Kinda of a dumb improvement, a cheap ATV battery takes a dump and your walking or getting towed?</end quote></div>
But you have to leave the dead battery connected don't you? I'm just going by what I've read and heard.
As far as a dumb improvement that's how cars work. I made it five miles with my old truck misfiring before it stalled out dead. I think my 1 cylinder quad would do better than the 10 times bigger V-8 did when it died. I hope I never find out, and I ran the quad to charge the battery earlier today. I should buy a tender for it.
Old May 13, 2008 | 07:46 PM
RticKwad's Avatar
Runs Stealth!
Default battery
Where can you buy new batteries for our sportsmans? More specifically the 06' Hawkeyes. I thought
I remembered a post about being able to even buy these quad 12v batteries at Walmart?
R'
