Gas in my Grizzly air filter box
Old Apr 28, 2008 | 09:18 PM
artsmg's Avatar
Default Gas in my Grizzly air filter box
Here is my problem...the 1999 Grizzly 600 would run but die out, then run again and die out. I took the cover off the air cleaner box and found that it was filled with black gasoline. The gas is coming up the crankcase ventilation hose. I'm guessing that there is a problem with the carb but I'm not sure. Does anyone have an answer? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 29, 2008 | 10:13 AM
Ujoint's Avatar
You need to check your engine oil and make sure you haven't filled the crankcase with gasoline. Gasoline in the crankcase is not good.........
The carburetor is flooding - probably due to a dirty needle and seat for the float. Try cleaning the carburetor and float needle/seat - you can use a golf tee to get into the seat and clean the sealing surface. If this doesn't fix the flooding, the float needle/seat may need to be replaced.
Old Apr 29, 2008 | 02:26 PM
artsmg's Avatar
Ok I'll give that a try, can I do it with the carb still on or do I need to take it off? I haven't looked at it yet.
Pgbama11
Jan 16, 2016 08:19 AM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Pgbama11
Sep 10, 2015 08:20 AM
black798
Sep 9, 2015 07:42 AM
